Core i7 Christmas '08 Graphics Performance
Written by Tim Smalley
December 17, 2008 | 13:42
Tags: #1gb #2008 #216 #240 #260 #280 #2gb #4870 #512mb #benchmark #card #crossfire #evaluation #geforce #gtx #hd #performance #radeon #review #shader #sli #x2
Companies: #ati #bit-tech #christmas #nvidia #test
Crysis
Publisher: Electronic Arts
Crysis is seen by many as the poster boy for DirectX 10 and it will make your system cry, quite literally – it’s a monster! It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game.
We tested the game using the 64-bit executable under both DirectX 9.0 and DirectX 10 with the 1.21 patch applied. We used a custom timedemo recorded from the Laws of Nature level which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game. We found that around 27-33 fps in our custom timedemo was sufficient enough to obtain a playable frame rate through the game. It's a little different to other games in that the low frame rates still appear to be quite smooth.
We set all of the in-game details to High and forced 8x anisotropic filtering in the driver menu as there is currently no support for it in game. We tested at 1,280 x 1,024, using 0x, 2x and 4x anti-aliasing, 1,680 x 1,050 using 0x and 4xAA, 1,920 x 1,200 using 0x and 2xAA and 2,560 x 1,600 with 0xAA and 2xAA. By extensively testing using anti-aliasing in very high resolutions in conjunction to Very High quality, we'll be pushing even the bleeding edge hardware on test to the limit.
Crysis
1,280 x 1,024 0xAA 16xAF, DirectX 9, High Quality
  • Nvidia GeForce GTX 280 1GB SLI
  • Nvidia GeForce GTX 260+ 896MB SLI
  • ATI Radeon HD 4870 1GB CrossFire
  • ATI Radeon HD 4870 X2 2GB
  • ATI Radeon HD 4870 512MB
    • 99.8
    • 59.0
    • 88.6
    • 54.0
    • 78.7
    • 44.0
    • 76.5
    • 40.0
    • 54.1
    • 32.0
    • 47.4
    • 27.0
    • 42.8
    • 24.0
    • 42.7
    • 24.0
50
75
100
Frames Per Second
  • Average
  • Minimum
Crysis
1,280 x 1,024 4xAA 16xAF, DirectX 9, High Quality
    • 86.7
    • 53.0
    • 75.0
    • 41.0
    • 66.0
    • 35.0
    • 63.9
    • 35.0
    • 46.5
    • 28.0
    • 40.2
    • 23.0
    • 35.2
    • 20.0
    • 34.9
    • 20.0
20
30
40
50
60
70
80
90
Frames Per Second
  • Average
  • Minimum
Crysis
1,680 x 1,050 0xAA 16xAF, DirectX 9, High Quality
    • 76.2
    • 41.0
    • 67.2
    • 36.0
    • 58.8
    • 32.0
    • 57.2
    • 31.0
    • 43.0
    • 28.0
    • 37.8
    • 23.0
    • 34.8
    • 20.0
    • 34.4
    • 19.0
20
30
40
50
60
70
80
Frames Per Second
  • Average
  • Minimum
Crysis
1,680 x 1,050 4xAA 16xAF, DirectX 9, High Quality
    • 66.1
    • 36.0
    • 57.6
    • 33.0
    • 49.5
    • 28.0
    • 48.1
    • 28.0
    • 37.2
    • 24.0
    • 32.1
    • 20.0
    • 28.2
    • 17.0
    • 26.2
    • 13.0
20
30
40
50
60
70
Frames Per Second
  • Average
  • Minimum
Crysis
1,920 x 1,200 0xAA 16xAF, DirectX 9, High Quality
    • 62.1
    • 36.0
    • 54.3
    • 32.0
    • 48.3
    • 26.0
    • 47.3
    • 25.0
    • 35.3
    • 22.0
    • 30.8
    • 19.0
    • 28.2
    • 17.0
    • 28.1
    • 15.0
20
30
40
50
60
Frames Per Second
  • Average
  • Minimum
Crysis
1,920 x 1,200 2xAA 16xAF, DirectX 9, High Quality
    • 56.9
    • 34.0
    • 49.2
    • 30.0
    • 41.6
    • 23.0
    • 40.5
    • 22.0
    • 32.1
    • 20.0
    • 27.6
    • 17.0
    • 23.6
    • 14.0
    • 22.1
    • 12.0
20
30
40
50
60
Frames Per Second
  • Average
  • Minimum
Crysis
2,560 x 1,600 0xAA 16xAF, DirectX 9, High Quality
    • 39.6
    • 21.0
    • 34.3
    • 18.0
    • 28.5
    • 11.0
    • 28.1
    • 10.0
    • 21.7
    • 11.0
    • 18.7
    • 10.0
    • 17.1
    • 9.0
    • 16.8
    • 9.0
20
30
40
Frames Per Second
  • Average
  • Minimum
Crysis
2,560 x 1,600 2xAA 16xAF, DirectX 9, High Quality
    • 35.6
    • 19.0
    • 30.4
    • 16.0
    • 24.4
    • 9.0
    • 23.9
    • 9.0
    • 19.4
    • 10.0
    • 16.4
    • 9.0
    • 14.0
    • 8.0
    • 4.2
    • 0.0
20
30
40
Frames Per Second
  • Average
  • Minimum
Again, at settings above 1,680 x 1,050 0xAA, the Radeons need to be doubled up in order to deliver acceptable performance, while the Nvidia GeForce GTX 200 series cards are able to handle 1,680 x 1,050 4xAA without too much trouble. The GTX 280 is also able to deliver playable frame rates up to 1,920 x 1,200 0xAA 16xAF as well – any higher than that and you really need a dual-GPU configuration at bare minimum to play Crysis with high detail in DirectX 9.0 mode.
null
